(((acourate))) - kennt das wer?
Edgar J. Goodspeed
Der Hersteller schreibt über den Verwendungszweck auf seiner Seite folgendes über das Programm, welches auch in Foobar einbindbar ist:
  • (((acourate)))® corrects for loudspeaker-room interaction anomalies in ways speaker designers cannot possibly anticipate. With extensive design and modification one can optimize a room to minimize effects on sound, but generally at great expense. This means realistically one optimizes room-response and layout as far as aesthetics and practicality allow, but the sound falls short of "acoustically correct."
    (((acourate)))® allows the user to ascertain the speaker in-room response and correct for the deviation incurred. Further, the program can provide precise individual speaker driver-time-alignment and linearize driver and overall loudspeaker response and then provide compensating real-time correction filters for playback.
    (((acourate)))® exceeds usual amplitude correction systems by doing both frequency response and phase response correction (minimum phase and excess phase). Time distortions are minimized. The frequency correction takes into account how the ear receives the sound by applying psychoacoustic principles.
    (((acourate)))® is also a powerful tool to flexibly design and implement digital crossovers, and complete subwoofer supported stereo loudspeaker systems.
    (((acourate)))® generates appropiate logarithmic sweeps which simply are recorded. This allows to compute the desired pulse responses with an optimum signal-to-noise ratio and without higher harmonic distortions . Then a correction filter is derived which runs during playback in high resolution at real-time, aka the "brute-force" approach. The filter algorithms used are the latest and most sophisticated, and can get frequently updated providing an advantage to to the quickly obsolescent hardware-based solutions.
Gibt's Erfahrungen eurerseits?
Ich lad grad die Testversion herunter. Mal sehen, ob ich damit zurecht komme :mrgreen:
tf11972
Has thanked: 183 times
Been thanked: 251 times
Re: (((acourate))) - kennt das wer?
Beitrag von tf11972 »
Ich hab mir grade die Anleitung zur Lautsprecherlinearisierung angesehen. Das ist mir zu kompliziert.
Und für mich würde es sich eh nicht rentieren, da mein Laptop am wenigsten als Musikquelle dient.
Thomas
Thomas
https://forestpipes.de
joe.i.m
Has thanked: 148 times
Been thanked: 247 times
Beitrag von joe.i.m »
Edgar J. Goodspeed hat geschrieben:Ich lad grad die Testversion herunter. Mal sehen, ob ich damit zurecht komme :mrgreen:
Hast Du schon was mit getestet :?:
Edgar J. Goodspeed
Ich wollt den Mann mal anrufen - irgendwie ist es mir bislang offen gestanden einfach zu komplex :sweat:
joe.i.m
Edgar J. Goodspeed hat geschrieben:Ich wollt den Mann mal anrufen - irgendwie ist es mir bislang offen gestanden einfach zu komplex :sweat:
Würd ich auf dem ersten Blick auch sagen.
Hab mal im WEB nach ihm gesucht, ist glaub ich im Forum "aktives hoeren" aktiv. Link: http://www.aktives-hoeren.de
KDR
Beitrag von KDR »
Frag mal im oef Forum bei Charly nach , der ist da ziemlich FIt.
e.akst
Beitrag von e.akst »
Habe im Forum aktives-hoeren schon viel darüber gelesen. Dort sind alles begeistert.
Also Edgar nach dem Verstärkervergleich hast du eine neue Aufgabe. Acourate testen, Erfahrungen posten und die Funktionsweise so verständlich wie möglich darstellen 8)
Edgar J. Goodspeed
Ich halt mich in jedem Fall ran. Der Preis ist bei versprochenem Mehrwert der Musikwiedergabe definitiv heiß!
Thias
Beitrag von Thias »
Edgar J. Goodspeed hat geschrieben:Der Preis ist bei versprochenem Mehrwert der Musikwiedergabe definitiv heiß!
... das ist ein absolut heißes Programm.
FIR-Filter.... Laufzeitkorrektur...Raumanpassung.... aktive Frequenzweichen.....
Bin leider auch noch nicht dazu gekommen mich damit intensiver auseinander zu setzen. Einiges an Wissen wird dazu notwendig sein. Dieses Programm kann einen FIR-controler für 4 T€ ersetzen...
Der Uli Brüggeman ist im aktiv-Forum aktiv :wink:
Zuletzt geändert von Thias am Do 23. Jun 2011, 19:13, insgesamt 1-mal geändert.
... mit (audio)vielen Grüßen
Thias
Meine Homepage
Meine DIY-HiFi-Kette
Meine Galerie
Edgar J. Goodspeed
Wie würdest du die klangliche Steigerung an einem System wie dem meinen prognostizieren?
