Grade habe ich ne PN verschickt, in der ich erwähnte, dass die 4 Button oben nur aus Text nud nicht Grafik bestehen, schwupps, ist das in Ordnung!
Lesen sie etwa meine PNs????
http://www.phpbb.com/community/viewtopic.php?f=14&t=772285 hat geschrieben:The changelog (contained within this release) is as follows:
* [Fix] Correctly re-assign group moderator on user deletion (Bug #280)
* [Fix] Deleting a forum with multiple polls included (Bug #6740)
* [Fix] Fixed postgresql query for obtaining group moderator in groupcp.php (Bug #6550)
* [Fix] Selected field on first entry by default for font size within posting_body.tpl (Bug #7124)
* [Fix] Adjusted maxlength parameters in admin/styles_edit_body.tpl (Bug #81)
* [Fix] Fixed html output in make_forum_select if no forums present (Bug #436)
* [Fix] Fixed spelling error(s) in lang_admin.php (Bug #7172, #6978)
* [Fix] Correctly display censored words in admin panel (Bug #12271)
* [Fix] Do not allow soft hyphen \xAD in usernames (reported by Bander00)
* [Fix] Fixed the group permission system's use of array access
* [Fix] Simple group permissions now work properly
* [Fix] Fix inability to export smilies (Bug #2265)
* [Fix] Fixing some problems with PHP5 and register_long_arrays off
* [Sec] Fix possible XSRF Vulnerability in private messaging and groups handling
