Was der Don treibt I: Endstufen, Verstärkerklang und dissonantes Verhalten (nuPower D, Purifi 1ET400A, Hypex NCx)
MiMatthies
Has thanked: 28 times
Been thanked: 59 times
Re: Was der Don treibt I: Endstufen, Verstärkerklang und dissonantes Verhalten (nuPower D, Purifi 1ET400A, Hypex NC1200)
Beitrag von MiMatthies »
Diese Module müssen ihre Abwärme über den Gehäuseboden abgeben können.
Ist also schon relevant, wie dick und aus welchen Material das Gehäuse ist, wenn mal längere Zeit lauter gehört werden soll.
Ich weis nicht, ob in den Modulen eine Thermische Sicherung/Schutzschaltung verbaut ist.
nuControl 1, nuPower D
Paffi
Has thanked: 466 times
Been thanked: 509 times
Beitrag von Paffi »
Ich habe nochmal mit Apollon geschrieben - der Kontakt ist schon gut, das muss man sagen. Meine Frage ging Richtung hörbare Unterschiede Hypex vs. Purifi.
so you really would say, that the difference between die purifi and hypex is noticable, even with such small speakers like the kef ls50 meta, playing not further down than 80/100hz? I thought THD+N / SINAD is in both cases already way above the human hearing capabilities. As I´m thinking to add a identical third (center) speaker, the monoblocks may be the better option.
Apollon:
yes the difference is quite audible.
Please note that it is not just the SINAD. Purifi has way smoother highs than the MP series from Hypex and the soundstage is night and day difference
Because of how the MP series are deigned especially the NC502MP and NC252MP, they have quite poor crosstalk performance of around 79dB whereas the Purifi mini has 120dB. Due to this the Purifi has way wider and more 3D stereo image.
The distortion of the Hypex MP series is 0.002% THD+N and our Purifi mini has 0.0004% THD+N. This is especially audible in high and high mid frequencies. Even in a blind test it is very easy to differentiate between both amplifier, because the soundstage of the mini is way bigger and it sounds smoother and more detailed overall.
I know that some people rave about the Hypex MP series on forums, because they are cheap, but most of them never heard the Purifi based or Hypex high end based amplifier. The Hypex high end modules like NCX500, NC1200 perform on a completely different level than the cheaper MP series as well.
The only MP series module I would recommend is the NC500MP, but sound wise and measurement wise the Purifi is still quite better.
die Antwort fällt überraschend deutlich aus. Also werden es wohl entweder NC500 Monos oder halt ne Purifi. Der angedeutete Blindtest würde mich tatsächlich mal interessieren.
Zu verkaufen: 2 XW700
Has thanked: 907 times
Been thanked: 762 times
Beitrag von aaof »
Sanftere Höhen? 8O Das darfst du gern mal ins HF-Forum stellen. Die Reaktionen dürften entsprechend deutlich ausfallen.
Aber mal ehrlich: für den Klang sollte doch der Raum und die Lautsprecher verantwortlich sein. :?
anphex
Has thanked: 205 times
Been thanked: 143 times
Beitrag von anphex »
aaof hat geschrieben: Fr 17. Mär 2023, 17:00 Sanftere Höhen? 8O Das darfst du gern mal ins HF-Forum stellen. Die Reaktionen dürften entsprechend deutlich ausfallen.
Class-D frequenzabhängige Verzerrung + in geringem Maße Umsetzung des low pass Flter der PWM Frequenz.
Also ja, sanfte, quasi "saubere" Höhen gibt es. Allerdings schreibe ich das persönlich mehr dem DAC Roll-Off Filter zu - und eventuell falsch eingestellte Abtastrate.
Aaof und Paffi müssen den Don oder mich mal besuchen :D
NuVero 70 Demo || Galerie
Paffi
Beitrag von Paffi »
anphex hat geschrieben: Fr 17. Mär 2023, 17:23 Aaof und Paffi müssen den Don oder mich mal besuchen :D
Vorsicht - ich bin öfter mal in Berlin :twisted:
Don Kuleone
Has thanked: 409 times
Been thanked: 135 times
Beitrag von Don Kuleone »
Falls du dich für Purifi entscheidest, würde ich empfehlen bei MD zu kaufen.
Stereo Amps sind idR günstiger als 2 Monos, falls es dir ums Geld geht.
Beitrag von aaof »
@anphex
Du wirst lachen, aber ich wollte das tatsächlich auch schreiben: wir müssen uns mal treffen. Gern bei dir oder Don (wobei ich die 170 ja schon mehr mag und endlich mal in Ruhe und gescheit hören möchte :mrgreen: ).
Der Corona Krempel ist ja nun vorbei. Machen wir halt mal einen nuDay und hören uns neben der tollen Lautsprecher auch Endstufen an. Meine Emo würde ich natürlich gern mal mitbringen. Dann ordentlich einpegeln und vergleichen.
Indianer
Has thanked: 111 times
Been thanked: 368 times
Beitrag von Indianer »
Paffi hat geschrieben: Fr 17. Mär 2023, 16:22 way smoother highs ... soundstage is night and day difference ... way wider and more 3D stereo image
ja lieber @Don Kuleone, warum hast du das nicht gehört??? sorry, Spaß :lol:
@Paffi, das ist wirklich brutales Verstärkerverkäufergeschwafel, hört man nicht alle Tage, blöd nur, dass unsere LS schon gut sind, wenn beispielsweise der Klirr deutlich unter 1% -40dB bleibt und die Intermodulationsverzerrungen unter 3% -30dB, das sind halt Fehler, die leider um den Faktor 1000 größer sind als die, die die angeblich so lausigen MP machen, remember nuPower A Level, oder Faktor 3000 größer als die der beworbenen "guten" Verstärker :roll:
Don Kuleone
aaof hat geschrieben: Fr 17. Mär 2023, 18:14 @anphex
Berlin wäre kein Thema für mich. Bin da eh öfters zum Tanzen.
Don Kuleone
Indianer hat geschrieben: Fr 17. Mär 2023, 18:22
Jaaa, also zur Hifiakademie von 2013 oder so habe ich Unterschiede gehört. Zumindest glaube ich das. Hab keinen professionellen Vergleich gemacht. Zur nuPower D vs Purifi kann ich nichts sagen, da die nuPower D schon auf dem Rückweg war. Die günstigen erwähnten Hypex habe ich nie gehört. Ich kann mir schon vorstellen das man ggf Unterschiede hört zwischen den Class D Generationen. Siehe dazu auch Technik satt Seite 14. Ob die Unterschiede so drastisch sind, wie vom Apollon MA beschrieben wage ich zu bezweifeln.
Meine neuen Endstufen find ich einfach geil…einfach so :)
