Forum-Update
A.Krapohl
der wo das forum betreut hat
Hat sich bedankt: 37 Mal
Danksagung erhalten: 68 Mal
Re: Forum-Update
Beitrag von A.Krapohl »
aktualisierung auf piwik 1.2.1
Piwik 1.2.1 is a maintenance release which fixes an incompatibility (introduced in Piwik 1.2) between the piwik.js Javascript file and other older version of Mootools and Prototype JS libraries. There is also a bug fix for Mysql 5 (strict mode) which was preventing new visitors to be recorded.
There are also other non-critical bug fixes included as well as updated translations.
This release does not update the Piwik database schema.
List of issues fixed in this release
#2165 piwik.js: JSON stringify not working with prototype < 1.7 and mootools < 1.3
#2153 Piwik Tracker throws SQL exceptions when using a boolean value for a tinyint(1) field
#2177 serveStaticFiles: better handle disabled readfile()
#2188 Segmentation in API to support greater/less than (or equal) as well as "contains" operators
#2124 Piwik 1.2 and IE9 RC -> empty dashboard
#2138 Default date to load is being ignored
#2148 Can't login if default site deleted
#2162 Invalid argument supplied for foreach()
#2151 UserManager.getUsersSitesFromAccess() doesn't order idsite
#2125 Piwik AutoUpdate (1.1.1 -> 1.2) failing with "Error Opening [absolute/path/to/piwik/latest/latest.zip]"
#2126 WebTest: add auto-update test from latest version
#2156 Update to JSLint 2011-03-05
#2150 Piwik_Option: add delete() methods and unit tests
#2173 piwik.js: getVisitorInfo()
#2178 Search Engines Update
#2154 IndexedByDate.getDataTableFromNumeric() lack of 'order by' breaks integration tests
#2176 WebAppGallery review/feedback
#2185 sanitizeInputValue() – improvements
#2187 update to ZendFramework 1.11.4
mit freundlichen grüßen
andreas krapohl
A.Krapohl
Re: Forum-Update
aktualisierung der mitgliederkarte auf geopmap 2.2.8
Caching-Problem beim Aufruf der Karte behoben
diverse kleinere Bugfixes
andreas krapohl
A.Krapohl
Re: Forum-Update
aktualisierung highslide (bildoverlay in galerie und bei dateianhängen) auf 4.1.12 inkl. deutschen sprachdefines
Version 4.1.12 (2011-03-28)
Fixed IE legacy problems after latest fix.
Version 4.1.11 (2011-03-25)
Fixed Ajax loading problem in IE9.
Version 4.1.10 (2011-03-16)
Fixed dimming in IE9.
andreas krapohl
A.Krapohl
Re: Forum-Update
aktualisierung auf piwik 1.3
Piwik 1.3 is a significant update that fixes bugs and adds new features, including: Custom Date Ranges, Performance improvements, improved Live! real time widget & Visitor Log, much improved Tracking API, and a lot more.
andreas krapohl
A.Krapohl
Re: Forum-Update
aktualisierung auf phpbb 3.0.9 (in den nächsten tagen könnten noch ein paar nacharbeiten notwendig werden...)
http://www.phpbb.com/support/documents.php?mode=changelog&version=3#v308 hat geschrieben:Changes since 3.0.8
Bug
[PHPBB3-217] - Multiline [url] not Converted
[PHPBB3-6712] - Topic bumping does not create new topic icon on index
[PHPBB3-7057] - Quicksearch uses POST, thus the page expires!
[PHPBB3-7778] - Increase limit of custom BBcodes
[PHPBB3-7834] - Correctly update topic_time when deleting first post in topic
[PHPBB3-7888] - URL of search results page does not always contain all keywords of the search query
[PHPBB3-7941] - mistake in description of function generate_board_url
[PHPBB3-8138] - Browser autocompleton fills wrong fields in ACP
[PHPBB3-8736] - Honour ACP settings for min/max username length when posting as a guest.
[PHPBB3-8802] - Wrong confirmation text when clicking "mark forums read" in a category
[PHPBB3-8904] - Show numeric CPF default value when editing
[PHPBB3-9166] - Subsilver and prosilver CSS elements out of order.
[PHPBB3-9348] - Correctly encode default_dateformat when converting from phpBB2
[PHPBB3-9575] - The word "administrate" is not correct.
[PHPBB3-9630] - Naming inconsistency of Merging Posts / Topics in MCP
[PHPBB3-9675] - Add option to delete template/theme/imageset when deleting style.
[PHPBB3-9685] - Unable to create "Fulltext native" search index using the mssqlnative DBAL
[PHPBB3-9751] - Password requirement "Must contain letters and numbers" is not working properly
[PHPBB3-9764] - Empty value for CONFIG_TABLE config_name= 'mime_triggers' causes functions_fileupload.php->fileupload->check_content() to be too restrictive
[PHPBB3-9851] - "Search new posts" should require login
[PHPBB3-9872] - Total topics isn't correct after I deleted a user
[PHPBB3-9874] - view_log() performs unneeded count query over all log entries.
[PHPBB3-9892] - Firebird index name length limit is not taken into account
[PHPBB3-9905] - DSN field should include SQLite
[PHPBB3-9908] - Send "Moved Permanently" before stripping off session ids for Bots.
[PHPBB3-9910] - Javascript bug in Subsilver2 PMs
[PHPBB3-9911] - Incorrect open/close field in Manage ranks ACP
[PHPBB3-9913] - currunt should be current
[PHPBB3-9915] - "Length of ban:" is not displayed in ACP
[PHPBB3-9924] - $template->display hook does not pass $template instance
[PHPBB3-9925] - prosilver logo margin bug in IE 6-7-8
[PHPBB3-9928] - Do not link "login to your board" to the "send statistics" page after completed update.
[PHPBB3-9930] - Redirect fails with open_basedir enabled
[PHPBB3-9932] - The Bing bot is not added when converting.
[PHPBB3-9933] - Wrong handling of consecutive multiple asterisks in word censor
[PHPBB3-9934] - Mass Mail missing under the system tab on a fresh install
[PHPBB3-9939] - JavaScript error in recaptcha ACP template
[PHPBB3-9944] - Extension groups naming don't use users' language in ACP
[PHPBB3-9946] - $inserts empty in sql_query() for oracle
[PHPBB3-9948] - Inline quicktime files won't display
[PHPBB3-9949] - $user->lang() is not handling arguments as per documentation
[PHPBB3-9950] - Problem with localized button images after uprading from 3.0.7-PL1 to 3.0.8
[PHPBB3-9953] - Set focus to password on re-authentication
[PHPBB3-9954] - u_masspm* permissions are forced to never for certain groups
[PHPBB3-9961] - Inconsistent activation logs
[PHPBB3-9966] - Language download in ACP creates index.html and misses captcha_*
[PHPBB3-9970] - user_lang input not checked during registration
[PHPBB3-9981] - Fix unit test dependencies on phpBB files
[PHPBB3-9985] - 3D Wave CAPTCHA mt_rand() does not check order of min/max values
[PHPBB3-9997] - Inconsistent approve/disapprove button order in modcp
[PHPBB3-9999] - {forumrow.L_FORUM_FOLDER_ALT} and {SEARCH_IMG} only return a language key.
[PHPBB3-10005] - users can register without custom profile field correctly entered
[PHPBB3-10011] - __DIR__ in test suite renders it unusable on php < 5.3
[PHPBB3-10016] - set_config_count() fails on PostreSQL 7
[PHPBB3-10020] - ACP function validate_range() fails partially on non-32-bit systems
[PHPBB3-10021] - "Find a member" generates SQL error when large dates are entered
[PHPBB3-10029] - No such thing as $_SERVER['HTTP_VERSION']
[PHPBB3-10033] - "Disallow usernames" does not check already disallowed names
[PHPBB3-10035] - ACP template edit feature allows to read any files on webserver and to upload/execute any script on it
[PHPBB3-10036] - Use image from configuration file for displaying online-status.
[PHPBB3-10038] - download/file.php uses $_GET value instead of function request_var()
[PHPBB3-10039] - 2.x to 3.x conversion fails when using mssqlnative to connect to destination database
[PHPBB3-10042] - GD captcha has invalid mt_rand calls
[PHPBB3-10047] - Session ID always included in URL on posting.php
[PHPBB3-10049] - Session test files are misnamed, session tests are not run
[PHPBB3-10052] - Session tests are broken
[PHPBB3-10056] - Firebird misspelled in database updater
[PHPBB3-10058] - Root path is undefined in MySQL upgrader
[PHPBB3-10059] - Consistent is misspelled twice
[PHPBB3-10060] - Typo in tests database connection manager
[PHPBB3-10068] - Firefox4 restrictions to :visited
[PHPBB3-10078] - commit-msg hook prints \n on freebsd
[PHPBB3-10081] - Cleanup Template Tests
[PHPBB3-10084] - Add smilie errors out when image is missing
[PHPBB3-10088] - Cache mock does not unset database versions other than mysqli
[PHPBB3-10090] - cache/queue.php.lock isn't covered by .gitignore
[PHPBB3-10092] - commit-msg hook aborts on overlength comment lines
[PHPBB3-10096] - Wrong whitespace in functions.php
[PHPBB3-10100] - Race condition in unique_id() on heavily busy database.
[PHPBB3-10102] - member.S_PENDING_SET in styles/prosilver/template/ucp_groups_manage.html
[PHPBB3-10104] - missing one intval() along with others already being there
[PHPBB3-10109] - Errors while copying a topic
[PHPBB3-10112] - Use of count() in captcha_gd.php and mssqlnative.php
[PHPBB3-10115] - BBcodes not working if post contains about or more 55000 non-english symbols
[PHPBB3-10117] - Big posts becomes empty if they have smilies on specified places.
[PHPBB3-10121] - ICQ profile link leads to a webservice that is no longer active
[PHPBB3-10123] - Inconsistent use of smilie/smiley
[PHPBB3-10128] - Error message is on green background when trying to ban a nonexistent user
[PHPBB3-10137] - Deleting an unintended space at the end of PHP_URL_FOPEN_SUPPORT_EXPLAIN
[PHPBB3-10146] - Firebird cannot handle DECIMAL(255, 0)
[PHPBB3-10147] - Typo in code comment in functions_template.php
[PHPBB3-10149] - deregister_globals causes error when cookie called GLOBALS is set to scalar value
[PHPBB3-10170] - reCAPTCHA address has changed
[PHPBB3-10171] - Firefox4 displays grey pixels at PM message rows when message is neither marked nor replied
[PHPBB3-10177] - phpBB package cannot be built with bsdtar
[PHPBB3-10178] - build.xml does not specify path to find - breaks on FreeBSD
[PHPBB3-10188] - Broken compressed output when errors/warnings are handled by phpbb and output_buffering is set to 4096 and phpbb gzip is enabled
[PHPBB3-10191] - Duplicate output when output_handler is set in php.ini
[PHPBB3-10192] - Missing semicolon in MySQL Upgrader
[PHPBB3-10195] - Do not check DNS Blacklists if IPv6 address is passed to session::check_dnsbl().
[PHPBB3-10198] - Function validate_config_vars() improperly validates multibyte strings
[PHPBB3-10203] - Fix quotations and hyphen in language strings for PHPBB3-10067
[PHPBB3-10204] - Package build tool does not detect binary file changes
[PHPBB3-10206] - Normalization tests fail when unicode.org is not reachable
[PHPBB3-10211] - Missing space on the recent PHPBB3-9992 changes
[PHPBB3-10213] - IP limit index name too long on Oracle
[PHPBB3-10214] - Cannot configure Q&A on Oracle
[PHPBB3-10218] - STRIP is not defined in style.php causing a notice to be thrown
[PHPBB3-10219] - Inappropriate character in web.config file
[PHPBB3-10220] - Logging in with Mobile Device triggers SQL error on *_login_attempts.
[PHPBB3-10221] - Inconsistent usage of "Seconds" in ACP Settings
[PHPBB3-7729] - Prevent date/time functions from throwing E_WARNING on PHP 5.3 by setting a default timezone
[PHPBB3-10223] - Updater references startup.php from board path
[PHPBB3-10228] - Typo in 3.0.9-RC1 user registration settings
[PHPBB3-10229] - On languge/acp/styles.php "%s" should be "%s"
[PHPBB3-10232] - Search within topic/forum searches all posts
[PHPBB3-10233] - IE Emulation fix breaks posting layout when PMing
[PHPBB3-10234] - msg_handler() reports E_WARNING as "PHP Notice: "
[PHPBB3-10247] - mediumint(8) too small for phpbb_login_attempts.attempt_id
[PHPBB3-10250] - phpBB Logo needs the Registered Trademark Symbol
Improvement
[PHPBB3-9581] - Banned users get mass emails.
[PHPBB3-9802] - Optimize session_begin REMOTE_ADDR validation
[PHPBB3-9878] - Get rid of Internet Explorer 7 emulation
[PHPBB3-9897] - Language typos in language/en/acp/board.php
[PHPBB3-9922] - Posting URL in subsilver 2
[PHPBB3-9937] - Feed Icon displays on Forum links
[PHPBB3-9980] - URLs to javascript should be T_SUPER_TEMPLATE_PATH instead of T_TEMPLATE_PATH
[PHPBB3-9989] - Skip PM popup in overall_header.html, if there are no new PMs.
[PHPBB3-10007] - Add directive 'internal' to blocked folders in nginx example configuration.
[PHPBB3-10009] - Differentiate published/updated dates in Atom feed
[PHPBB3-10014] - Make the error message when cache is not writable clearer
[PHPBB3-10024] - Allow a Style to present Unread PM in different way than read PM
[PHPBB3-10040] - Continuous integration on PHP 5.2
[PHPBB3-10041] - download/file.php needs more use of send_status_line
[PHPBB3-10044] - Setup github network improvements
[PHPBB3-10057] - More informative reporting of errors when database connection fails for Firebird and PostgreSQL.
[PHPBB3-10067] - ACP options for account activation are confusing when emails are turned off board-wide
[PHPBB3-10069] - Improvements in sample nginx config file
[PHPBB3-10072] - Send the post number to the template as it relates to it's position in the topic
[PHPBB3-10101] - Compatibility with native phpass hashes
[PHPBB3-10126] - Replace ^ with &~ in error_reporting calls
[PHPBB3-10141] - Performance improvement for $auth->_fill_acl()
[PHPBB3-10145] - Ability to force recompilation of all templates on every page load
[PHPBB3-10154] - Move "copy permissions from" to below "parent" in forum creation form
[PHPBB3-10158] - Return link not really useful after sending a Private Message
[PHPBB3-10186] - UCP signature panel displays when not authed for signatures
New Feature
[PHPBB3-9942] - WinCache Caching Module
[PHPBB3-9992] - Limit amount of failed login attempts per IP
[PHPBB3-10110] - Redis caching module
Task
[PHPBB3-9788] - Add README for GitHub
[PHPBB3-9805] - Add a script for setting up git remotes for a github network
[PHPBB3-9806] - Script for easy merging
[PHPBB3-9824] - Git hook quirks
[PHPBB3-9859] - Remove the years from visible copyright in the footer.
[PHPBB3-9921] - Add sample configuration for lighttpd webserver
[PHPBB3-9943] - Setup phpDocumentor API documentation generation
[PHPBB3-9967] - Use phpunit.xml for test suite
[PHPBB3-9987] - Enforce _test.php suffix for test files
[PHPBB3-9990] - Integrate utf normalizer tests into test suite
[PHPBB3-10043] - Refactor phpbb_database_test_case
[PHPBB3-10046] - Getting rid of register_shutdown_function() in cron.php to prevent path disclosure (reported by lacton)
[PHPBB3-10075] - Update docs/AUTHORS for 3.0.9-RC1 release
[PHPBB3-10079] - Add gallery avatars to .gitignore.
[PHPBB3-10082] - Fix Session Test Issues with CHAR vs. VARCHAR.
[PHPBB3-10105] - Update AIM express link and "Download Application" links
[PHPBB3-10107] - Improve docs for non-apache webserver configuration
Sub-task
[PHPBB3-9732] - Cover session code extensively in tests
[PHPBB3-9968] - Create unit test for word censor regular expression
[PHPBB3-9969] - Move word censor regular expression creation into separate function definition in functions.php
andreas krapohl
A.Krapohl
Re: Forum-Update
aktualisierung "Did you know?" auf 1.3.2
https://www.phpbb.de/community/viewtopic.php?f=88&t=173213 hat geschrieben:nur kosmetische fehlerbehebungen (versionsnummer)
andreas krapohl
A.Krapohl
Re: Forum-Update
aktualisierung "NV advanced last topic titles" auf 1.3.2
http://www.flying-bits.org/download.php?mod_id=2 hat geschrieben:[Fix] "This forum is protected." when topic was moved (Bug: #797)
andreas krapohl
A.Krapohl
Re: Forum-Update
nuMarkt integration (basiert auf classifieds mods 1.0.0, ist aber massiv angepasst) :wink:
andreas krapohl
A.Krapohl
Re: Forum-Update
galerie aktualisiert
http://www.flying-bits.org/viewtopic.php?f=98&t=3357 hat geschrieben:1.1.2:
[Change] Make phpbb_gallery_config easier to extend for plugins (Bug #852)
[Change] Require phpBB 3.0.9 so we can clean the function_phpbb.php file a bit.
[Change] Check phpBB and php version requirements during install/update
[Change] Use a button instead of a text link for inserting the images from the popup
[Change] Populate path and ext variables for MODs that added include() (Bug #845)
[Fix] Fix also display BBCodes for images, when comments are disabled. (Bug #860)
[Fix] Fix various errors in the new upload process (Bug #859)
[Fix] Do not display "Add more upload fields" link for limit=1 (Bug #858)
[Fix] Add option for displaying the thumbnail for next/prev image links (Bug #857)
[Fix] Fix "Column 'image_desc' cannot be null" error with outdated style (Bug #856)
[Fix] Fix Undefined class constant 'REPORT_UNREPORT' (Bug #853)
[Fix] Fix quote option on (recent) comment search (Bug #851)
[Fix] Fix display of the input-boxes when the page is less than 1024 pixels wide
[Fix] Fix Fix several usages of old constants in convertor scripts
[Fix] Fix pruging the "cache", the correct path is thumbnail
[Fix] Fix quick-moderation language in image_page, when comments are disabled
[Fix] Fix typo in table name: Use of undefined constant GALLERY_CONTEST_TABLE
[Fix] Error in block: Always reset the mode and display when the function is called
[Fix] Correctly install cleanup module in ACP
[Fix] Fix debug error messages in acp config when functions are disabled (Bug #850)
[Fix] Personal Gallery icon does not appear on viewtopic (Bug #847)
[Fix] Do not try to use plugins on upload, when none is installed. (Bug #843)
[Fix] Breadcrumb link from moderation-overview leads to album_id=0 (Bug #842)
[Fix] Purge permissions cache when deleting permissions (Bug #841)
[Fix] Store exif data when we set the status to saved in database (Bug #840)
[Fix] image-page displayes wrong data for uploader (Bug #839)
[Fix] Fix error when deleting comments (Bug #838)
[Fix] Fix contests with undefined constant and undeclared property (Bug #837)
[Fix] {NUM}-explanation missing on ACP import (Bug #836)
[Fix] Fix typos in de-package and rephrase a string in en-package (Bug #834)
[Fix] Undefined class constant 'DB_SAVED' (mistyped DBSAVED) (Bug #833)
[Fix] Fix error while editing a contest-album (Bug #832)
[Fix] SQL Error when reseting rating of an empty album (Bug #831)
[Fix] Correctly state, which folder needs to have the CHMOD in install/ (Bug #830)
[Fix] Code for pruning is not working and the lang-string is missing (Bug #829)
[Fix] Fix code for hotlink prevention (Bug #828)
1.1.1:
[Fix] Fix copy operations in XML files (delete and add some directories) (Bug #827)
[Fix] PHP Warning: in file /includes/gallery/user.php on line 334: Invalid argument supplied for foreach() (Bug #826)
[Fix] Index name ... on table ... is too long. The maximum is 24 characters. (Bug #825)
Final:
[Fix] Jumpbox allows jumping to invalid albums (Bug #823)
[Fix] Restrict autoloader to gallery classes (Bug #821)
[Fix] User option for blocks not working correctly (Bug #820)
[Fix] Add missing quick moderation to subsilver2 (Bug #817)
[Fix] Error when testing user permissions (Bug #818)
[Fix] Gallery throws error when there are permissions for deleted albums (Bug #816)
Beta 1:
[Feature] Add zip-upload feature (Feature #426)
[Feature] Add popup to phpBB/posting.php with own and recent images aswell as an upload option (Feature #421, #446)
[Change] Rewrote the upload part, so it's easier to name and describe the images (Bug #809)
[Fix] SQL Error on gallery block when user has no permissions (Bug #812)
Alpha 1:
[Feature] Add option to go to next image when clicking on image_page (Feature #798)
[Feature] Add friends and foes control to personal galleries (Feature #749)
[Feature] Use "Last-Modified"-header to cache images in browser (Bug #747)
[Feature] Add option to quote a comment (Feature #744)
[Feature] Add option to change contest winner tabulation (Feature #730)
[Feature] Add option to allow changing the "uploaded by"-information (Feature #729)
[Feature] Add option dis-/enable the signature on comments (Feature #719)
[Feature] Add option to create personal gallery for users in ACP (Feature #714)
[Feature] Add option for uploader to disable comment for images (Feature #704)
[Feature] Add option to prune albums manually in the ACP (Feature #680)
[Feature] Add recently reported and unapproved iamges to MCP-Index (Feature #437, #658)
[Feature] Add RSS/Atom Feed for new images (Feature #312)
[Change] phpBB Gallery Integration throws errors while installing/updating the board (Feature #801)
[Change] Change install to use UMIL for database changes (Feature #788)
[Change] Make image description invisible until the end of contest (Feature #718)
[Fix] SQL-Error for MSSQL when trying to rate an image (Bug #791)
[Fix] Several typos, wordings and wrong quotation-marks (Bug #789, #799)
[Fix] Change error handling on upload-page to continue after corrupted files (Bug #781)
[Fix] Remove confusing message about number of upload-fields (Bug #767)
[Fix] Resync contest winners, if a winner get's deleted (Bug #751)
[Fix] Call garbage_collection() to free some memory before viewing images (Bug #696)
andreas krapohl
A.Krapohl
Re: Forum-Update
http://www.flying-bits.org/viewtopic.php?f=98&t=3407 hat geschrieben:1.1.3:
[Change] Add option to hide the update advice for a week (Bug #879)
[Change] Rename submit button on first upload step to "continue" (Bug #878)
[Change] Add option to open image-links in new tab (Bug #877)
[Change] Fix inconsistent naming of a_count and a_unlimited permissions (Bug #865)
[Change] Remove GALLERY_ROOT_PATH constant (Bug #863)
[Change] Add album-feed to feed-list on image_page (Bug #873)
[Change] Allow embeding two different blocks on the same page (Bug #874)
[Fix] "Instant Redirect" breaks album information update on upload (Bug #881)
[Fix] Fix two little bugs in html code of ACP (Bug #880)
[Fix] Hide name of uploader on feeds for contest albums (Bug #876)
[Fix] Fix inserting smilies from popup into image description (Bug #875)
[Fix] Fix invalid feed format (Bug #870)
[Fix] Fix invalid feed format (Bug #870, #871)
[Fix] Add links to feeds, when they are enabled (Bug #869)
[Fix] Fix rating not possible in subsilver2 (Bug #868)
[Fix] Fix Undefined variable: image_id_id_ary when removing favorites (Bug #864)
[Fix] Fix typo in language packages (Bug #867)
[Fix] Correctly link back when deleting the personal main album (Bug #866)
[Fix] Remove ../ parts from the url when gallery is besides the forum (Bug #862)
andreas krapohl
