Hier mal das (gekürzte) Fazit:
und weiterWhats best for you? Of course it is important to match the best product with your own equipment and environment. In my case I went from a white screen which I loved, to a grey screen which took me a long time to get used to, and finally a silver screen which Im having more fun with than... Its kind of like the first time I started watching High Definition material Im still watching in awe.
If you want no-nonsense performance and accurate delivery of colors and whites I highly recommend a white-based screen. If you are trying to overcome some limitations of your equipment or environment, like poor black level, a grey screen may be for you. If you want what is possibly the best of both worlds and an awesome punch to your image, you should really consider what Silver could do for you.
I hope that others manufactures will consider the benefits of silver and start working on their version of the best of both worlds Until then, bravo Vutec! what a screen!
I think we all like good blacks. But good black really is a function of the darkness of your Home Theater and the limitations of your projector. Trying to cheat this with a grey screen is really only cheating yourself out of the real image. Check this out..
recht gut gemachter und interessanter Vergleich, solltest Du Dir wirlklich näher ansehen.Did you even notice the green leaves in the left pictures on the grey screen? Did you even notice that there was a red flower on the grey screen? This is mostly because this is a grey screen reflecting less light/image.
bin mal gespannt, was am Ende bei Dir rauskommt
Bo.
