kennt jemand diese Kombi
Nakamichi AV1 / 7.1 Preamp/Surround Processor
Quelle = http://www.nakamichi.co.uk/products/nak ... -processor (alt)
NEU = http://stylco-electronics.myshopify.com ... -processor
Manual = http://www.nakamichi.co.uk/docs/AV1_user_manual.pdf oder https://cdn.shopify.com/s/files/1/0815/ ... 6013348875
Preis = £199.99 zzgl.Steuer & Versand[/b]
[edit 15.05.2015] aktuell die AV1 Vorstufe VERSCHWUNDEN von der Page... ...alles weggekauft
[edit 17.05.2015] neuer Shop = http://stylco-electronics.myshopify.com/ [edit-ende]
...und...Specification
Multi-signal inputs and outputs
DAB/DAB+/FM Tuner
Bluetooth Audio Streaming, with APT-X support
Support wide range ways of audio processing, including HD formats, such as Dolby TrueHD, DTS Master, Dolby Digital Plus, DTS HRA and SD formats such as PRO-LOGIC Dolby DIGITAL, DOLBY DIGITAL-EX, DTS, DTS-ES, DTS NEO:6
Support multiple HDMI video formats
Supports HDMI CEC Control and has HDMI ARC Audio Channel
Professional OSD. Any operations of the unit can be seen on the TV display.
USB port to connect to PC for software upgrading, parameter setting, preferences selection.
Customized setting and memory
Full function remote control (included)
Automatic Intelligent Room Calibration (Free Microphone Supplied)
Audio Management: Front, Centre, Surround, Rear Surround, Front Height and Subwoofer Speakers have adjustable crossover points in 20 steps from 40Hz to 250Hz
Crossover slopes can be set at 12db or 24db per Octave
11 Band Parametric Equalizer
Bi-Amping feature for front L and R channels
Nakamichi AVP1 / 7-Channel Power Amplifier
Quelle = http://www.nakamichi.co.uk/products/nak ... -amplifier
NEU = http://stylco-electronics.myshopify.com ... -amplifier
Preis = £399.99 zzgl.Steuer & Versand[/b]
Specification
Amplifier Gain: 29dB
Input Sensitivity: 1.1Vrms, 47Kohm
Power Output:
250W with 4ohm load, 2 Channels Driven
170W with 4ohm load, All Channels Driven
150W with 8ohm load, 2 Channels Driven
110W with 8ohm load, All Channels Driven
Signal to Noise Ratio
Unbalanced Output: ≥107dB
Balanced Output: ≥110dB
THD+N: ≤0.06% (Rated Condition: A weighting)
Frequency response: 10hz-60Khz (+/-3dB)
Other
Power: AC110 to 230V, 50/60HZ
Power Supply: high output toroidal transformer with 90,000uF storage capacitance
Max Power Consumption: <1900w
Standy Power: <0.5W
Nett Weight: 32 kg/70.5 lbs
Gross Weight: 34.6 kg/76.2 lbs
Packing Size: 570mm x 616mm x 330mm
Unit Size: 430mm (W) x 450mm (D) x 200mm (H)
Supplied with RCA inputs and fully balanced XLR inputs
High Quality Binding posts, accepts 4mm banana plugs or heavy gauge speaker cables
NAKAMICHI hat aktuell nur diese eine Heimkino-Kombi, die ich aber ziemlich interessant und beachtenswert finde,
daher dieser Thread.
Gesamtkosten = £639.98 (aktuell ~895€) ...und das für eine 7ch-Vor-Endstufen-Kombi
Versandkosten nach DE sind mir aktuell nicht bekannt
Ansonsten einfach anfragen, denke ich
[edit 06.Mai 2015] reale Gesamtkosten incl. Versand nach DE = 986€ -> siehe http://www.nubert-forum.de/nuforum/view ... 47#p821947 [edit-ende]
[edit 27.Mai 2015] reale Gesamtkosten incl. Versand nach DE = 1031€ -> siehe http://www.nubert-forum.de/nuforum/view ... 95#p828395 [edit-ende]
Die Quali wird gut sein - auch klanglich - da die nahe Verwandschaft zu Emotiva unübersehbar ist, gerade bei der Endstufe (siehe Emotiva XPA-5 & XPA-7),
aber auch bei der Vorstufe erkenne ich Ähnlichkeiten zur ehemaligen Emotiva UMC-1
Das Herstellerwerk in China wird wohl das gleiche sein
[edit 12.05.] Bildbericht zur NAKAMICHI-Kombi von "Derry12" -> http://www.nubert-forum.de/nuforum/view ... 75#p824175 [edit-ende]
Gruß vom Rudi
